Hi everyone,
Normally I work on bicycles but now i have a derny (simple motorcycle built for cycling races) in the shop. But on low power and middle power its stuttering of stalling. I added a few pictures of the motor and would like to know what could be the problem. I already cleaned the carb.
Thanks in advance.
ps how can i share a video of the stutter?
Automotive tire Motor vehicle Automotive lighting Motorcycle Automotive design
Tire Wheel Vehicle Automotive tire Automotive lighting
Tire Wheel Vehicle Automotive tire Motor vehicle
Automotive tire Motor vehicle Rim Automotive wheel system Gas
Tire Crankset Wheel Bicycle tire Automotive tire
CB125T, EX250 commuter, Ninja 250 racebike, CBR250R(MC19), VF500F, CBR600RR, VFR750F
"clean the carb" is not so simple in black&white, all-or-nothing, yes/no terms. "How" it was cleaned is more important:
  • complete disassembly down to every last nut, bolt, individual component?
  • PEA-based cleaner or carb-cleaner?
  • soaking or scrubbing?
  • ultrasonic?
  • micro soda blast?
  • all rubbers replaced?
  • float level measured and adjusted?
  • float level functionally "wet" tested?
  • any mixture screws? were they adjusted?
  • ultrasonic?
  • micro soda blast?
  • complete disassembly down to every last nut, bolt, individual component? Yes
  • PEA-based cleaner or carb-cleaner? Carb-cleaner
  • soaking or scrubbing? Scrubbing
  • ultrasonic? No
  • micro soda blast? No
  • all rubbers replaced? Checkd they where completely fine
  • float level measured and adjusted? Measured
  • float level functionally "wet" tested? No
  • any mixture screws? were they adjusted? Set back to original when I took it apart
  • I hoop this helps.
