I hate polishing. But I have to on the newer and or cleaner bikes. My 79 XS1100 is disgusting. So is the XS400. They are the winter bikes. The salt **** rusts the steel bits, and tarnishes the aluminium alloy casings. So to practice before I work on the mint 80 XS1100 I attacked Yami. Bought polishing wheels and tried all kinds of stuff. What works?
The sand blaster was the winner. But I need to strain the sand. the bigger bits are interfering with flow.
The wyre brush worked well on the cylinder fins.
The soft polishing units spinning in the drill, have little impact. I will try some more severe units. Can not find the wyre wool, so that did not get tested.
The critical thing for the winter bikes, is keeping them running. Everything wants to seize, like the side stand pivot point. So I blast it with lube, which spreads about. Solid and liquid grease are my friends.
In about weeks I will blast both of them with the pressure washer, trying to avoid the wheel bearing and spark plugs, and other sensitive bits. Will blast my van cage too.
UK
UK
