Much like spray paint it seems like paint stripper has changed formulation since the last time I used it. It USED to bubble up paint and make it fall off. Now it turns the paint to IMPOSSIBLE TO REMOVE GUM
People stripping indoors, not following or reading the label.It seems some of the chemicals in paint strippers are being banned due to deaths. The most recent ban was in 2019.
It's been a couple years since I last used a chemical paint stripper, so I'm not sure what's the best out there.
No, let it sit longer and/or reapply it. It WILL remove the paint. I’ve used it and it takes longer on old bike’s paint.Much like spray paint it seems like paint stripper has changed formulation since the last time I used it. It USED to bubble up paint and make it fall off. Now it turns the paint to IMPOSSIBLE TO REMOVE GUM View attachment 65085
Nope, just gels and turns sticky. Had to blast it off with a power washer. Three hours with a power sander and 80 grit pads finally got the job done.No, let it sit longer and/or reapply it. It WILL remove the paint. I’ve used it and it takes longer on old bike’s paint.
Don't think so, the rust is on the outside of the stamped flange not at the seam and this isn't the first time I've encountered it.Moisture is probably coming from inside the tank, even if coated. I would think that any paint remover for plastic would be not as effective as one created for metal only. Is sand blasting an option??
