My brother-in-law was just given his dad's Honda Shadow. It's an older one, but we are not 100% sure the year. We do believe it's somewhere between 86-89. Anyway, his dad has had it sitting in his garage for the last 20 years or so. We know that it needs some where, but want to make sure we start in the right place.
We had a terrible time moving it. First off, all the lock mechanisms are frozen up, so I had to unbolt the ignition cylinder so I could get the handlebars unlocked. Secondly, the front tire is extremely hard to turn. I just glanced at it really quick, but it looked like either #1 , the bearings in the axel are dry or need replaced, or #2 , the brake calipers are seized up and pushing the pads onto the rotor. (It does turn with some effort, but not easily).
Aside from that, the rest of the issues are mostly cosmetic. (Seat is all torn up, the chrome has surface rust on it, and the metal trim is pitted and stained.) Before we do any major work to it, I wanted to remove the spark plugs, put it up on the center stand, and attempt to turn the motor over (To make sure it's not seized up). That's going to be my first step.
After that, I had planned to remove the carb, give it a thorough cleaning and replace any gaskets/orings/jets that are damaged/worn, and start working on the rest of the stuff.
Is there anything else I need to keep in mind when seeing if this is worth restoring? I would think that as long as the motor turns over, everything else should be salvageable?
Thoughts/suggestions?
