That really doesn't makie much sense. A valve stem seal shouldn't leak that much, unless it is just totally non existant.
I assume the cylinder not firing is the one that has the oil coming from it?? If so, what you say doesn't explain why it wouldn't be firing. Replace the plug, and get a new end on the plug wire to be sure that's ruled out.
If you have problems with the plug wire ends, check with Napa, if they have problems, tell them to look in the Belden/Napa Wire catalogue.
