1 - 15 of 15 Posts
Does anyone use the K&N (303 in my case) oil filter on their bike? I picked one up yesterday. About twice the price I have been paying for a Fram at Walmart. Honestly, the primary reason I wanted it was for the nut on the front of it, as I have a hard time using the filter wrench on the Fram ( it slips a lot) when I am trying to use the torque wrench to get the specified tightness. Is it worth the extra money, ie: is it that much better of a filter? It might be worth the money to me to not have to dick around with the filter wrench (and ppl walking past my garage are less likely to learn a highly creative filthy vocabulary), but is the filter itself worth the money? Please advise.
MODERATOR
Steve, I use K&N filters on most everything I own because of that crazy little nut on the end:biggrin: From that time on, it makes a filter change a snap.
The Fram filters that I've used on my ZTR mowers all have a black, thick, rubberized end coating that makes them as easy or easier to change than the K&N. If one has a strong enough grip, a torque wrench is hardly needed.
I have never used a torque wrench on any oil filter in my life as I have the "FEEL" for it and a vein on my right forearm pops up at the correct setting;)
Sam:coffeescreen:
K&N makes excellent filters. So does my less expensive preference, Wix. Neither has let me down.
I say, if it's worth it to you functionally to have the nut, it's worth the money. As for the guts of the filter, probably not. Less expensive filters will do as good a job. This is motorcycles, though. There's folks who will pay extra for a chrome oil filter because they like the looks.
Now, for air filters, I do prefer K&N. Not becuase it gives me 100 extra horsepower and 50 more miles per gallon, because it doesn't. I just think it's a good filter, and like that I can hose it off rather than replace it. I've had one in my truck for well over 100,000 miles. No problems. The one I had in my first bike also did fine. The NCX will have one once it's the mileage to replace the stock.
Veteran Member
If the nut makes a difference, then there is no reason not to use the K&N. They are good filters. You are paying for the convenience of that nut. If the nut is not needed, then you can certainly use a less expensive but just as good filter. I use WIX filters on everything. I think they are a good fit between quality and price. But I don't have a problem accessing the filter, so the nut is not needed. On my old sport bike, I planned on going to the K&N because the filter was behind the exhaust headers and was a damn pain in the ass to get any tool at. I sold the bike before the next change was due.
Sam:coffeescreen:
Does the vein have a specific foot lbs setting? Or does it vary based on the need?
I put them in fingertip tight and never have a problem removing them by hand. Never had one leak or loosen on any vehicle. I think many places tighten them too much.
From what I've read lots of people here put them on too tight.
But even after putting them on, turn until they hit resistance, then 1/4 turn, easy to do by hand, I haven't been able to take it off by hand at the next service.
I honestly think they tighten themselves too. I put mine on hand tight, then I back it off 1/4 turn. I've never had one get loose and still had them feel like some gorilla put it on later. I've never had the guts to try using just 2 fingers but it would probably work.
A lot of people do put them on too tight, yeap.
An end wrench is also handy for when I'm changing someone's oil after they've ridden a ways to get here. Keeps my fingers off a hot filter and away from a hot engine case. :)
Veteran Member
I just wish I could figure out a way to keep the oil in the filter from flooding my Ultra's lower frame/engine mount area. On the Sportster I am able to get a homemade "trough" under the filter and get most of the oil to flow down it and into a pan. But on the Ultra you have the lower and floorboard in the way.
I've used a big wad of paper towels to catch the oil, flipping the filter up as soon as it's free to minimize how much oil spills. It's still a mess.
On an Ultra I use a rag to cover the shifter and floorboard, then flip the filter up as soon as I can like Dodsfall described. I use Brake Klean to spray off the part of the crank case below the filter that get's dripped on and let that run into a cookie pan underneath for a couple minutes while I'm checking the brakes or drive belt or something.
I use a refillable sprayer like this one:
https://www.google.com/shopping/pro...M3niMgCFUYqHgodZ0UMdw&ei=eFMAVqaZHcbUeOeKsbgH
1 - 15 of 15 Posts
