I have an Italika DM150 (I'm in Mexico for the winter). A few months ago, the clutch developed a quirk: if I tried to pull it in & start in 1st gear, the start button wouldn't work until I let it out a little... it's been like that ever since.
A couple days ago, the start button stopped working entirely and the Neutral indicator went off. When I dropped the bike down a curb (to start it by rolling down a hill), the Neutral indicator came on & the button worked again. So it seems that something's loose.
Now, if I can get the Neutral indicator to come on, when I push the start button, as soon as I hear the solenoid click, the indicator shuts off & power dies. No power is getting to the starter (which does nothing).
Also: if the Neutral indicator is on and the bike is not running, as soon as I turn on the lights (right side controls) OR signal L/R (left side controls), the indicator shuts off & power dies.
If the bike IS running, the lights and signals work, but the indicators all sort of flicker as the engine runs... again, almost like there's a loose connection somewhere.
Anyone have any idea what's going on? I'd like to fix this myself if I can (I've looked at the manual, but it's shorter than the manual for my DVD player lol). Any help appreciated!
Greatest Member Ever
Always start with the battery. Make sure the connections are clean and tight. Then you need to start jiggling wire harnesses until the lights flicker. I would also be suspect of the starter interlock switch. It is a small switch that the clutch lever activates. You stated that at times you have to let the clutch lever out a bit.
Update: Yep... Always check the battery
I put the battery on a tender overnight & it's running OK again. Good lesson, one that I'll always remember: no matter how odd the symptoms, it could just be a weak battery. Thanks for the advice...
Thank YOU for the update!! Not everyone takes the time to come back and let us know we helped. Ride safe!!!
Jack
