I bought a 2003 GZ250 in boxes and have been building it over the months and I have ran into the strangest no spark problem.
The bike turns over (on the starter) horn and all lights work. I have checked and replaced basics such as fuses, battery, spark plug, kill switch and stand switch.
The existing stator in the engine is burned but is reading between 0.1 and 1.5 ohmes. As the stator was burned I replaced it anyway. Brand new stator fitted, same readings but no spark.
I tested the ignition coil working off of a battery so this couldn’t have been the problem. Wiring harness is reading 12.6V all over including up to the CDI, ignition coil, relay and starter relay.
I have replaced the pick up coil twice as it looks like the previous owner has before.
it would be greatly appreciated for any help or ideas.
Thanks
Thanks
