Hey everyone. Hope you're having a wonderful day.
I own a Honda CB125R 2018 (125cc, single cylinder, 4-stroke) and am approaching two years of riding. That means it's about time to change the coolant. Even if it isn't, I still need to drain it, for reasons I'll come back to in a minute. However, it seems my bike has no coolant drain. Please refer to the image provided.
Encircled is what I believe is access to the coolant pump. However, as far as my knowledge goes, this is usually where a coolant drain sits. Which as you can see, on this bike, it doesn't.
Some of you might say it's too early/not necessary yet to change the coolant on this small bike, but even if you're right, I still need to decouple the encircled part because I require access to the right side of the engine block.
Here's my question: is this the way to drain the coolant on this bike? It does seem to be the lowest point in the loop, and I cannot find a drain anywhere else on the bike. I found no guidance in the owner's manual either. I think it's strange Honda provided no (apparent) way to leak the coolant, but given the fact this bike doesn't even have an oil filter, it wouldn't surprise me.
Many thanks in advance! 😄
