1 - 2 of 2 Posts
I have a 92 Kawasaki ZX 600D3 I have put a new battery and carburetor rebuild, solenoid new , starter new relay new But the bike won't turn over only with starter fluid just for a few minutes and then cut off... I tried to crank the bike up with a half of tank
Well, if it fires with starter fluid, then dies when the fluid is used up, you aren't getting fuel to the intake. So, somewhere between the fuel tank and carb output the path is blocked. Open the drain on the carb, then set the fuel valve to RES (PRI if a vacuum operated valve), to see if fuel is reaching the carb. If it is, the carb may not be filling, or the passages still blocked into the jets.
1 - 2 of 2 Posts
