my bike is running rich. I have already changed spark plugs fuel pump plus oil and oil filter and a new airfilter as well bikes starts but runs rich. filled the tank twice and only put 10 miles on it. its a cbr954rr 2002 so its fuel injected. changed sparks again after trying to fix what I could diagnose. one is really black other three are fine and brand new changed the other one again also. fuel is going to oil pan. what is most likely wrong with my bike. two out of four pipes are hot outside 2 are cold. tried to clean injectors after the process I got one out of the two not previously hot hot. the other one Luke warm. tried starting again both stay cold again. do I have a engine problem or just need injectors professionaly clean. if you have a blown or cracked gasket caused from over heating would the bike run on two cylinders or is it something else
