Starting
I am not familiar with your bike but it may be similar to my old Yamaha. The solenoid relay has two heavy wyres to carry the starter motor loads, two smaller wyres, and one thick red that provides power to the systems.
Check the thin red / white or similar colour with the key off. Should be zero volts. Check again with the key on. If there is a large voltage drop, there is something not connected correctly along the way. Could be the key switch, kill switch, or whatever else is in its path. Mine was corrosion in the connectors.
Fixed that and still had intermittent starting. Was corrosion in the starter button wyres at a connector.
Your bike is newer so not likely corrosion.
Unkle Crusty*
