First there is this issue of fork oil.
I have never, ever, worked on forks, so I ckeck out the anti-dive on this and it requires I drain the oil. Looked like a good quality 10w to me. What exactly is fork oil, and why is the proper weight so important?
Second, The XVZ is the tedious of all machines on two wheels, to work on.
Am I missing a better eye, or a system they made to simplify all the stacked on components? The aftermarket manual I have, does not help much as per the types of screws a nd bolts that hold the plastic to the plastic, and the style of fastener that holds the frames together so I am guessing, adjusting and seem to making a good ole general mess of things.
Tell you, there is a fairing on a little plastic innerfariing that is bolted to the subframe which is bolted to the main frame....the hoods(?) that hold the electronic and ride components, are fastened american style to the upper arm rest style fairng holes, and it is all very heavy for the plastic they used.
So heavy in fact, that the repair I did with epoxy on the right speaker holder, broke loose the second I tried to move it.
Computer brains like mine, dream of the mainframe... so I suppose my sloth might be due to secondary superflouos subject(SSS) invasion.
