565797 Views 7770 Replies 252 Participants Last post by  Heartbroken
2441 - 2460 of 7771 Posts
Here ya go... If this is acceptable, next challenge is your bike in front of a Caterpillar piece of equipment... has to be Caterpillar brand.
Cool! It's really tall.
You have to scroll down a bit, but it's the Manage Attachments button found under the Additional Options.
You're right. I didn't look below the "submit" button.
The tower is 50 feet tall... built it myself to match Aermotor specs, so that part is only about ten years old... a little less than a few centuries. ;)
It's different from modern windmills that energy companies build, but it looks very much like the mills that the Dutch have been using for ages to pump water out of our polders. A lot of these mills for pumping the water out of the small canals into bigger canals, and one big mill to pump the water out of the polder.
I was thinking of the windmills used to grind grain. I never considered the electricity wind turbines or the windmills used to pump water for cattle and such. Yeah, we have thousands of those kinds.
Windmills in the Netherlands, the old ones, serve two purposes. Some grind grain, others pump water. The water pumping is not for cattle, they don't pump the water up. Water is only a foot deep, some places only inches, so no need for pumping. The mills pump the water out of the areas that are below sea level. Or they used to, now there are modern engines doing the same. If they switch off the pumps, a lot of our country would gradually flood because of the water that slowly comes through the dikes.
Then we have tons of modern windmills, that all generate electricity.
Don't know if there are other dummies like me out there. I had to look it up so I figured I would share:
Polder
A polder is a low-lying tract of land enclosed by embankments (barriers) known as dikes that forms an artificial hydrological entity, meaning it has no connection with outside water other than through manually operated devices. There are three types of polder:
Land reclaimed from a body of water, such as a lake or the sea bed
Flood plains separated from the sea or river by a dike
Marshes separated from the surrounding water by a dike and subsequently drained
The entire link:
http://en.wikipedia.org/wiki/Polder
Sorry about that. "Polder" is a word we use a lot. I didn't realize it needs explanation.
On Google Maps, when you type "Haarlemmermeer Netherlands" you'll see an area reddened that is the "Haarlemmer meer polder". It used to be just Haarlemmermeer, where "meer" means "lake". with a number of steam engines, they pumped the water out, now it's land. The red line around the area is a canal, into which the water from inside the lake was pumped, and into which the water from the small canals in the polder is pumped now. The water level in the canal is higher than the land.
The north-east edge of this polder is about three miles from my home.
Any day I learn something is a good day so no apology needed Christine. It may have even been something I might have known at one time and forgotten. :)
If I would have known you were going to give me the definition, Critter I would have kept on reading. I had to look it up too. Thanks Christine for giving us something to look up. :)
So, no one is able to find some Caterpillar heavy iron? :icon_cool:
Give them more then one day, dude.
I was just used to the fast pace of earlier responses... :p
I do realize this messed up extended winter has put constraints on many of us. :(
I'll try to be patient. :smiley_drinkcoffee:
Well I went to every construction site I could find but no Cats all Japanese stuff so I dropped back to the Coffee shop with a little extra
In the background above the white pickup you see the word JOINT, that's a pot shop, If I walk out to the street I can see 4 more, its crazy here.
I don't have any tires or wheels on my bike right now, otherwise I would knock this one out. Changed the tires and took them down to the bike shop but their spin balance machine was down. If this challenge is still here when I get them back, consider this one done:icon_cool:
BTW nice pic of the coffee shop Muggs!
Cant help but notice there are no empty parking spots. :)
Man! This sucks! I'm still snowed in! I know TONS of spots out here that I could get that picture. Can we revist this one in May? lol
I actually use a few pieces of CAT equipment at work but two are down for service (d-5 and d-8) and our CAT lift won't make it through the deep snow to get into the storage building my bike is in.
Gixxer that's a pretty neat idea. At the reg't I'm working at we have a
D-7 dozer. I wonder how much $#!T I would get in if I tried to steal it and drive it up to my garage. lol
With 50-60 degree weather in MN this week, I think it's time to get back into the game! It's been a long winter!
