I was wondering how well the motorcycle community would like this design, due to the lack of motorcycle spots currently in our cities.
I believe this design when used on the edge of a handicap spot, will provide a double stacked space for motorcycles. Because of the maneuverability of a motorcycle the inner one should be able to maneuver through the no parking buffer zone, if a second motorcycle parks behind them. I personally do not own a motorcycle yet, due to being in high school, and can't afford it. But wanted to know your thoughts on this concept. I believe that if designed correctly, this type of parking spot can be applied to every parking lot in our cities, finally giving the motorcycle community a fair and safe place to park.
One of the advantages of this, is also as many of you observed when people often abuse the handicapped spot, blocking people who truly need the space for a ramp to access their wheelchair or mobility device, the motorcycle spot should alleviate this problem. The only risk I can see is that it may be more likely a handicapped person may hit your bike, but I believe having a dedicated spot outweighs the cons.
Note: This design, takes up the space of 2 normal parking spots, for the legal handicapped spot minimum, no parking zone minimum, and exceeds motorcycle spot minimum. In order to make this practical, there will be the need for a few variations. This is just a rough start of what I'm thinking could be implemented.
