Hi mikuni cv carbs on suzuki gs850 . been working on my trike for some time, now its out on the road it hangs back after third gear pops back from carbs just wont run nice starts on the button. Ive done whole carb clean brand new inlet boots floats spot on ive noticed it has over sized mains 130 instead of 115 so in theory should run rich, but dont . i think the pods are cheap and nasty ive put masking tape round all pods leaving about half inch at the narrow end and now trike runs almost perfect just a bit of deceleration backfire plugs are all a good colour .could this bad running problem be just useless pods or have i missed something, ive got 142 new mains ordered to try giving it more fuel to air. Oh forgot the carbs are properly balanced and float levels are spot on. Ive tried to cure the problem by adjusting mixture screws the tape blocking some of the air has the best results ..... engine is good with almost new engine compression. If it may just be the pods letting in to much air any recommendations for better pods would be appreciated
many thanks in advance
