I went to start my 93 vs1400 the other day and it was dead. I took out the battery to find the negative terminal was melted and battery was at around .2 volts.
I did some diagnosis and found a short between the negative battery cable and the positive post on the starter. I replaced the starter but I'm still getting continuity between the negative battery terminal and the positive post on the starter. I know the cable from the solenoid to the starter is not shorting.
Any ideas?
Thanks!
Any ideas?
Thanks!
