1 - 12 of 12 Posts
Hi all,
I just got back from Asia recently and most of the scooters and bikes there have a manual lever, that when triggered, will cause the headlight to flicker. I thought it'll be a nice option to have on my bike.
Does anyone in here know if such kit is available in the States and where can I get it?
Thanks a thousand,
Spyderboy
I have seen something similar on the new gsxr's it was a "passing light" or something like that. It was meant to just flash the headlights but it came stock on them.
I have a Ducati GT1000 that came with that little passing button, not something I use just cus I dont want to tick people off (They may get the wrong idea) but I thought most bikes came with it stock? Unfortunately I dont know where you can get that as an aftermarket option.
Banned
i have been debating adding one of these modulators to my bike. the prices range from ~20.00-125.00+ depending on how complex the device. they really do make you stand out more.
Exorcising My Angels
^ How's that? My headlight modulator had to be wired into my headlight system. The taillight modulator, though, was plug n' play.
Plugged one end into the bike end...connected to bulb to the other end...presto!!! blinking headlight when it's on high beam :) There is sensor so when it gets dark it will stop blinking but you just connect that somewhere..handlebars ... with a tie.
Interesting. Mine's a bit different because it's also wired into the horn (you can change the rate of blinking using the horn) and the bike's own light sensor.
Ive got lots of the Comagination units on my scoots....all are plug and play 5 minute deals. All work and have worked as they should for many years.
I also have the comagination tail light blinkers setup on the same bikes.....they were not plug and play but not difficult to splice in.
Great stuff....
1 - 12 of 12 Posts
