I changed all the 'dash' lamps to LED, the speedo and the tail and license plate bulb, too. I didn't change the turn signals, because of the issue of 4-way flashing if you don't mod the indicator with steering diodes and a ground. BTW, when I did it, they didn't have a LED bulb that fit the license plate light socket, so I broke a filament bulb and soldered in a LED. I put a 35W HID in the headlamp, which had a decent but not perfect pattern. If you can find a quality LED bulb at about 30W, it will be better, provided the pattern is good.
The main reason I changed the tail and license plate lamps weren't to save power, as the bike has plenty, but for those times when one turns the key to stop the engine, and it ends up in P instead of OFF. That leaves the tail and plate lamps on, which will kill the battery in a few hours; switching to LED changed that to days. The other LEDs were for better color and brightness.
