1 - 7 of 7 Posts
I installed HID kit on my 2008 GSXR 600 about a month ago with everything working properly and yesterday I noticed my low beam wasn't working. Both high beams work fine. I have tried the bulb on the other switches and it works fine, ballast is fine with everything else. I narrowed it down that it has to be the green plug from the bike that is screwed up. I even plugged in stock bulb and that still didn't light up so it has to be the green plug/wiring from the bike. Anyone have this problem in the past and have advice/solution for me? Could it be a fuse?Thanks
I'm not 100% sure that the high/low beam use the same fuse, but I'm fairly sure they do. It wouldn't hurt to check, though, and I would do that first.
I would check for voltage at the socket first, then check for power at the switch, then back at the fuse block. That will help localize the issue.
Nevermind!! I got it, it was the fuse. I took out one of the fuses and saw it wasnt connected and put in a spare one and it worked! Thanks for the help!
Can you please let me know which fues have you replaced and its location please
Thank you
You know you are posting on a thread that is 7 years old? Those two people are no longer even reading these forums.
You should go to the new member introductions forum and say hello, tell us a little about yourself and your bike. Somebody will be sure to help you.
1 - 7 of 7 Posts
