So I just Set up my 6v LED intagrated tail light, the front and rear blinkers work but are dim, and both brake lights shine fully when applied. Front turnsignal bulbs are still stock non LED. So that may be the issue restricting flow or maybe it's the relay, idk. But my main issue is the running light doesn't work at all but could it be because my headlight coils is popped? one coil is split in two and the other is disconnected at the base. If you can help I'd really appreciate it! Thanks!
