1 - 8 of 8 Posts
· Registered
2021 Harley Lowrider S, 06 TTR250, 04 KX250F, 82 CB650
So another one of the bikes in my pile is a kx250f that I got off a guy who made a mistake. Unfortunately in another way its turning into my mistake or at least issue. It was always super difficult to start and had issues getting it going... rebuilt the carb and has some success until a buddy dropped it and the generator cover smashed.
Finally got that fixed and and moving on to get it started....
Carb is cleaned and set and should be good to go. Checked the valves and found the one exhaust was way to loose. Got that sorted and put back in.
Now the kick start seems super tough almost catching ish... but grabbing might be a better term.. super stiff and won't start..
Any ideas?
I'm gonna take the cams out and reset the timing ect but should be good anyway... and yes there good spark.
Thanks
Material property Font Tints and shades Cosmetics Close-up
Tire Wheel Fuel tank Automotive fuel system Vehicle
Motor vehicle Automotive tire Automotive exterior Rim Gas
· Registered
Discussion Starter · #2 ·
Turns out the camshaft cap has been compromised.. there's a big gouge and the position ring is a mess and a half.
Automotive tire Wheel Finger Rim Tire
Hand Finger Bicycle part Thumb Gas
Will mend this issue and see where that gets me. Will check clearances again and try once more.
· Registered
Discussion Starter · #4 ·
Will do. Currently talking with kawasaki for parts and you can't get the camshaft cap by itself it's only come as the whole head. And then when he looked that up, it was unavailable. Looks like I'll be cruising ebay for parts.
· Ace Tuner
According to my hard parts supplier the cylinder head, Part Number 11008-0009, has been superseded to 11008-0080 and is shown as available.
Partzilla does not update to the new number and showed the head as unavailable but when I plugged in the new superseded number... Available
Your Kawasaki dealer may not know the part number changed or my supplier (and Partzilla) might not know it has been discontinued but I would try the superseded (11008-0080) and see what happens. Wouldn't be the first time a part got lost in numbers.
· Registered
Discussion Starter · #6 ·
Thanks, will give him a shout today. He was gonna get in touch with his machinist to see if he could repair the cap. I'm not too stoked on $800 for a full head replacement just for one cap. But knowing my luck I'll have to do the top end anyway so will see what happens.
I'm closely approaching the point where I'm not interested in going further. I set a limit of what I was willing to put into the bike and getting close to that line.
1 - 8 of 8 Posts
