Kawasaki Z650RS gearing change
1 reading
5K views 7 replies 4 participants last post by  brian10x
#1 ·
I've got a 2022 Kawasaki
Z650RS, and it seems to me the rpms are a little high at cruising speeds on the highway here in Arizona.
Speed limit is 75mph in most places, and the rpms are usually hovering just below 6000 when I'm following the traffic flow.
Maybe the bike is designed for sustained rpm this high, but my gut feeling is it might be a little more comfortable minus 500 rpms or so on the highway. Seems to have enough torque in 1st gear to overcome a gearing change.
Any suggestions?
Thank you!
Brian
Sunny Arizona
#2 ·
My suggestion would be peck around and find a Kawasaki 650 forum and you will probably find your answer pretty quick. I'm on a Ninja 1000SX specific forum and there is plenty of information about riders on that bike that have switched out sprockets added a in the front and taking away from the rear to provide lower rpm at highway cruising speeds. The 1000SX has plenty of torque so this doesn't effect the lower gear performance much. However, on later models going to much may cause the ECU to throw a code. You may also find valuable information to possibly step up a tire size on the rear (little larger diameter) to help reduce rpm a little bit and might improve turn in performance. I know there is at least one other active member here riding a 650, maybe she or others will have something helpful.
#3 ·
BTW what is your high today in Sunny Tucson, about 105, that's not to bad, we are in the low 90's up here in the White Mountains today and my house A/C went out! Not that it has anything to do with your question!!
#5 ·
Those revs at these speeds are normal for this engine sizes. Engineers are not concerned much with RPMs, as everything turning is doing it either, on hi press oil film (plain bearings), or metal bearings, but they care about piston speed which is a function of stroke, and this is what determines red line on the tach...........
Meaning; the shorter the stroke, the higher they can rev w/out any excess dynamic load banging on the crank.,,,,and yes, these engines can go all day at high revs w/out problem.
....however, higher revs feel a bit frantic and makes people nervous, specially when they are used to cars (with much longer stroke), so if it bothers you, you can go a couple of teeth higher on front, and that would drop revs about 500 RPM.....at the expense of course, of acceleration.
#7 ·
[/QUOTE]
Thanks for your input. On my Honda, I installed a larger front sprocket, but it is my understanding that on the Kawi, there is not enough clearance to use a larger one in front. So, maybe a smaller rear sprocket would be a good compromise.
Nowhere in my owner's manual does it say what size rear sprocket I have though. I suppose I could just get my lazy ass out to the motorcycle and count teeth.
