Volt meter
Get a small digital volt meter if you do not have one. $20- should do.
Check the battery volts, always if it does not run. 12.25 volts is a half discharged, or half flat battery. A clicking sound from the starter motor usually indicates a flat battery. Bike batteries do not have a lot of reserve cranking power. They lose volts quickly, especially in cooler weather. Most everyone uses a battery tender connected to the battery when not in use. A tender is different to a charger. If you charge the battery, do not set the charger at anything higher than about 2 amps. Leave it on for a day and disconnect. Check the volts. It might be 13.25. Check again after a couple of hours. Should be around 12.75.
Check again after 6 hours. If it has dropped a bunch, say down to about 12.3, then the battery is not holding a charge. You can also use a load tester on the battery. I am still not sure of the temperature.
When it is cool, below 45 F is cool, use full choke and do not touch the throttle. I think you said it is a 006, if so it might be fuel injected. If it is, turn the key on and press the button. The computer can figure out what to do. Some bikes with fuel injection might respond to a teeny bit of throttle. But usually no throttle is needed.
For bikes 32 F is the beginning of cold.
For folks from the prairies, zero is the beginning of cold. Makes the trajectory of footballs veer off course.
Unkle Krusty*
