I just got a 2006 VTX 1300R with 50k miles on it, vance and hines longshot pipes
The owner had passed and his friend took it over for a short time, the manual has really good service notes that he did and it seems that he changed oil, filter and plugs every 4k miles for the bikes entire life
The guy who had it said he cleaned the carb and changed the petcock to the tank and no issues with it
I went to the house to see it, it fired up, I rode it around and bought it,,,,I have been riding the bike around town for 3 days, not much maybe 15mi a day
The other day, I was close to home and it started sputtering and hesitating and stalled out, I chocked it, it came back on, then slowly died out again
So heres what I have done so far,,,,,oil looked good, changed 1k mi ago,,,,coolant levels look good,,,,Took bottom float bowl off, there was some sediment in bowl, cleaned and inspected jets and passages, clean with carb cleaner,,,,,,,,removed and inspected fuel petcock, drained tank,,,,,replaced all 4 plugs, at removal looked like a little "rust" on plug, crud it boot,,,but i dont think its a spark issue,,,, it said valve adjment was at 16k miles, it now has 50k
Bike will start and idle, throttle rips loud, but sounds kind of lean with some tinny sounds and popping (just my guess)
I let it idle but something sounds off with the idle, gallopy, lean, somthing just sounds off to me,,,,but throttle response rips, touchy and strong
Pop in it gear, get about 500ft, it starts to sputter and hesitate then stalls out and wont start again till later
It has the V&H Longshots,,,main jet is 185 and pilot is 55
why would it ride fine for 3 days then just sputter and stall all of a sudden?
My guess so far is that maybe its not tuned or jetted properly, maybe too small main jet? Maybe air fuel mix off?
Any ideas you guys can give me or some direction as to what to do next would be great, Id love to get back on this thing!
TY all
Thedaydreamer
TY all
Thedaydreamer
