Hi, sometimes when the bike is some hot, under acceptable parameters, the dash board behaves a little crazy, all control leds (gas, oil, temp) blink, and the rpm meter needle, being on idle, moves about 1k, in a one second pattern, after a while, everything turn normal. Whats happening, i think is that i need a new regulator, because it does not throw enough power anymore, i used volt meter, it throws about 13.5v on 5k, while a new regulator should throw around 14.5, right? So what do you think about this? Stator is few months old, while regulator may be several years old, who knows, i got the bike used condition (yamaha fz1 2005). Also im not ignoring that although 13.5v may look not too bad, we have to take in account the current, i mean, amps, it seems that when regulator get hot, they lose capabilities, which is doing it mine, but also the inside parts may have finish their life span, i got no good readings even with a cold bike. Head lights show a turning light pattern, barely noticiable, but telling that theres a voltage drop.
