My local shop says that I should match the make/model of the front and rear tires on my Honda Shadow Spirit 1100. But with the Covid shut downs, I can't get a new front tire. Is there really any benefit to matching the front and rear tires?
you can switch out make and model if your bike will fit them ( i.e. things like knobbies or paddle tires) but you are obviously going to want to stick with the same size tire that fits your rim.My local shop says that I should match the make/model of the front and rear tires on my Honda Shadow Spirit 1100. But with the Covid shut downs, I can't get a new front tire. Is there really any benefit to matching the front and rear tires?
This only works when traveling in a fairly straight line; when turning, the tires follow separate paths.The claimed wet surface performance of some of the higher street legal tires come from matching the tread design of the front to the rear, where the front pushes the rain away from the road surface the rear contacts and the rear thread designs then takes advantage of the rain pattern left from the front so in combination they achieve better wet traction.
I was going to say that, but decided to keep quiet. Everything is generally fine in a straight line, as long as we avoid deep puddles. Steve Baker passed me on the outside of a tight corner, going sideways on a TD2B Yamaha. It was pissing rain. He did something that is impossible for mere mortals. Only about three of us went fast in the rain. Steve was faster.This only works when traveling in a fairly straight line; when turning, the tires follow separate paths.
Maybe if you ride more, you'll be ready to switch out before they come out with the 23s, and you can keep your extra 1/2 tire? Ride more, save more money!I used to mix and match.. until .. I tried the Battleax S21's. .... I was so impressed by ... the S21's I continued to run matching tires front and rear and now I using the newer S22,
The guys at the shop love me as when I switch sets they get a half used front!
That, to me, is a brilliant way to put how I feel.--
I've mis-matched bias and radials, bias and car tire radials, radials and car tire runflats, specified front tires on the front and then gone to a rear tire on the front, and in all cases (note, this is with street tires), it never seemed to matter. EVERY TURN AND CURVE you make when riding is going to be different EVERY TIME YOU RIDE IT. That said, I'm not sure how a rider can really tell if there's a difference in cornering or stopping unless they are an expert and on a closed course under identical conditions. Otherwise, they're just subjectively guessing. You can tell the feeling is subjective when the words "it seemed to me" have been injected.
The thing is, we adapt to the different conditions of the roadway, temporary condition of our bike, and the condition of our physical body all the time. If you don't adapt, you'll never be able to ride city streets and country roads. Wouldn't it be boring if everything was the same every time we rode?
Your assumption is far from factual, but I understand that happens a lot. I get 7-8K miles on the rear tire of S21's and S22's. Between the 2 bikes I change tires about 3 times a year. I buy tire sets that are 3-6 months old and therefor never are riding on aged rubber. I don't change my own tires and get a better deal on the tires and change cost when changing both front and rear as a combo then trying to get a few more miles out of the fronts, and the bikes are in the shop less. Works for me. I'm not stating my opinion to convince anyone that my way is better for them, only that my way has become the best for me. I'm open minded and always wanting to learn so I like reading how and why others conduct their rides. So far in this thread I haven't read anything that will change my approach, but I'm still reading and listening.Maybe if you ride more, you'll be ready to switch out before they come out with the 23s, and you can keep your extra 1/2 tire? Ride more, save more money!
Wow! ...These days I use so called sport tires, front and rear. I only get about 3K out of a rear most of the time.I get 7-8K miles on the rear tire of S21's and S22's.
