1 - 2 of 2 Posts
Cleaned the carbs, replaced the floats etc and put the carbs back on, almost. I am having a hard time getting throttle cable fastened to the slide. Between the cable, the spring and the slide, I am having a hard time hooking the cable to the slide. Is there a trick to it?
Discussion Starter #2
And the answer is . . .
Disconnect throttle cables at both ends to give yourself more cable to play with at the carb end. Did the trick. Wisdom courtesy of Steve at Motoworks in Chicago.
1 - 2 of 2 Posts
