1 - 15 of 15 Posts
· Registered
Hi there, I am trying to install LED turn signals on the rare end. This is a Yamaha Virago 1100. It has only two wires for turn signals and the new LED turn signal lights have three wires. I have no idea about wiring. Can someone help me please!!
Thanks!
Funny man Oz. Hey Cmon may need your help with the BMW he has. Check the chatbox
Reactions: imeshnu1
· Registered
I've read that installation of LEDs into turn signals is a pain, because they hyper flicker and may throw errors. That's the reason why I even didn't try installing them into any of my vehicles...
Forgot to mention, that sometimes this flickering can be fixed by wiring a load resistor into the chain. Just in case if you notice that flickering and stuff.
· Visionary
It's usually easier to just change to a LEd flasher, then they work fine. Only a couple of bucks in the auto parts store.
· Loves All Motorcycles
Shoot, I had to install an electronic flasher relay just to get my Goldwing's turn indicators to work again. The added reliability and versatility are simply bonuses. :)
You will either need to install resisters in the lines to each bulb or get a flasher designed for LED lights. The just don't pull enough juice to let the flasher know that they are there, so it thinks a bulb is burned out.
· Premium Member
I just put LED lights on the back of the XS400, only they don't flash. Regular bulbs up front. And I did not test them when the old rear lights were on. Ordering a new flasher unit soon. Have been riding the 400 at night in the nearby city. Thought it would be a good idea if folks new where I was going.
UK
I put a custom module on the Springer with the LED lights. It gives me turn signals, 4 way flashers and an extra set of brake lights.
Reactions: Retired Guy
1 - 15 of 15 Posts
