1 - 8 of 8 Posts
· Registered
I have a 07 Honda Shadow Aero and was thinking about adding an inline fuel filter onto the bike. But, after I took the tank off I see the tubing is 3/8 and all the filters I found are 1/4 or just a hair bigger. The only 3/8 i have found is to big to fit in the area under the seat so was wondering if anyone knows of a filter that will fit. (Gas tank had rust in it so was thinking of a second line of defense after the screen on petcock in the tank)
I would not be afraid to put a glass filter in. this you can put any combination barb you want provided it isn't too big as well. You can contact them and get exact measurements as I didn't see that level of detail.
· Registered
I have a 2006 Shadow Aero VT750C and used a Mr. Gasket glass inline fuel filter in the line from the petcock to the carb, it comes with several different sized fittings and mine used the largest one (3/8") , I don't know if it does anything more than the petcock screen, but it sure made me feel a lot better about having it there. Also, these type of filters are small and you can buy cartridges for them when they need to be replaced for about $8.00 for three. I got mine at O'Reiley's Auto Parts for around $12.00. This really seems cheap for the piece of mind that it gives me. Hope this helps.
Just remember if you start having fuel related issue it may be the filter. It doesn't take much to cause a problem even if relatively new. I've not confirmed this but read recently that water can cause a filter to be plugged. I don't really want to confirm it either. Just remember the filter should be the first thing to check with any future fuel problems.
· Registered
2005 Suzuki C90T
You can get those glass filters at any autoparts stores. I beleive they element is treated somehow to not allow water to pass. Lowes has this exact filter in the lawnmower isle.
1 - 8 of 8 Posts
