hello im new here sorry to get right on with it but I really need my bike for work and im having a serious problem
I have a 2005 Honda shadow 600 and first it started dieing on the highway but then would start back right back up then it kept getting worse now im to the point were itll start and run but has only 7 volts everywhere the lights are flickering and it wont throttle up at all just idle
now ive pulled the whole wire harness apart looking for a loose or bare wire but I found nothing and the stator was producing erratic voltage like 4 to 8 volts so I just replaced that but still doing the same thing I checked the regulator and all diodes are working theyre all at 4. something one way I checked all the fuses and changed the oil
voltage is at twelve at the ignition switch and once that is turned on it drops to seven but at first sometimes it would read twelve but now just seven and I load tested the battery at 10 volts it had like 100 amps is that right for this bike what kind of cca should I expect
if anyone has had a similar problem or has an idea what to test im getting desperate
