1 - 20 of 40 Posts
:LOL:
Are you keeping the races and just replacing the bearings?
Have you ever tried roller bearings in the stem?
Discussion Starter · #4 ·
I have new races and seals on the way just in case.
Roller bearings: This is why I didn't pose this on kawiforums.
Want to stick with balls for now. Just can't figure whether chrome or ss is the way to go.
I'm feeling some AC/DC coming on
Discussion Starter · #8 ·
By chrome, do you mean chromium steel, or chromed steel? One is an alloy, the other plated.
Here's some info: Bearing Materials - Ceramics, Chrome Steels, Stainless Steels, and Plastics | Engineers Edge | www.engineersedge.com
Not really sure. I mean I'm sure chrome plated wouldn't be good. I would think that would easily chip.
All balls has a kit. Or I pound them out, and ask for decent new ones from the bearings shop.
With the kit in hand, it is a same day job.
UK
I already have all other parts coming (OEM). I will decide whether or which ones to replace once I inspect it. I'm just hung up on the balls. The good news is, either one (chrome or ss) I can get in a few days. The races may take a couple of weeks.
If you're not changing to tapered bearings, why not just order std balls from Kawasaki?
Balls are just balls aren't they?
Kawasaki wants $0.95 per ball. I need 39 balls. Buying from other sources they can be had for ~ $5 - ~$7 for a bag of 50 - 100.
"Balls are just balls aren't they?"
Now I did give fair warning.
Discussion Starter · #9 ·
Actually let me come at it from a different angle.
Does anyone even make chrome plated ball bearings? Because it doesn't make sense to me why they would. So I would think the chrome ones would in fact be solid chrome steel.
Chrome plated would be worthless to my way of thinking. If any of the plating cracked, it could flake off causing other problems.
Yes, there are chrome plated bearing balls, just not for the kind of bearing here. Usually, they are actually brass, so for very light duty; the chrome makes the surface last longer, since brass degrades so fast.
Discussion Starter · #14 ·
I think most of the MC manufactures use chrome. Not sure about Kawi, they like to keep this info under wraps. Hopefully if I go chrome I won't get some flaky duds.
Discussion Starter · #20 ·
Update:
Balls-a-coming
Bag of 50 chrome G10 grade. Now the bad news. An OEM seal is on back order.
I hate it when that happens
1 - 20 of 40 Posts
