1 - 2 of 2 Posts
Hello all!
Thank you in advance for taking the time to read this post.
The situation is I have a 2003 UM Renegade that has a kickstart spindle and can have a kickstart lever installed. The problem is the dealer I can get almost anything else from does not sell a lever.
What should be the process on finding a fitting and compatible kickstart lever.
Below is a diagram of the spindle. Forgive me if the answer is obvious. I am still a novice.
alpha-sports.com/um_parts.htm?q=united-motors-parts
Most of these companies use many of the same parts on different models, and even different brands, so I would start at the UM web page and try calling different dealers based on where you are. If your closest dealer doesn't have the part then try others and see if they'll ship it to you.
I looked at the schematics and it looks like your kick start arm would be part number 21200-L044B-000. I'd have a dealer make sure of that though.
1 - 2 of 2 Posts
