I found out the reason that I've got a big pool of gas under my bike. I seems it has something to do w/the leak in the fuel system. Imagine! Well it seems the problem is this line leading out of the cutoff valve to I-don't-know-where (strangely, there are 2 lines going out of the cutoff valve. One to one of the engines, and this one). Oddly enough I can't find anything in my Clymer manual telling me what to replace them w/. Can anyone tell me? It's also got these little metal clamps wrapped around them.
You can get fuel line at any automotive supply store. Make sure you get the proper interior diameter (ID) hose. It will help if you can bring in a piece of the old one.
Most factory hose clamps can be replaced with standard aviator clamps.
Well in this country we have this store called "Canadian Tire". They wouldn't know a hose from a hoser there. I can bring the old one in, but can you give me any guidance on getting the right one?
Aviator clamps? That doesn't sound all that basic a part. Is it more widely available than it sounds?
