1 - 1 of 1 Posts
· Registered
I've fully swapped a 91 FZR600 sport bike engine to a new 92 frame to register it and everything's 95% complete with the project. However my earth/grounds got torn in the process so I have absolutely no grounds. Everything wiring wise on my bike is set up correctly using the wiring diagram. However I have no power at all when I turn the key. I plan on ordering the ground wire connector with 2 other leads that look like - battery terminals and another set of ground wires however I'm just unsure of where I would exactly set them. Do I plug in the ground connector and drill 1 on to the frame and put the other on the negative battery or the engine. And with the second set of grounds do I put it on the starter motor or by it and the other on the nut holding the voltage regulator.??
1 - 1 of 1 Posts
