Im new so now sure how this all works.
Im having RT switch assembly probs, hit starter button and get nothing but headlight goin on and off with each push??? any ideas
Welcome to the forum.
You might have a nearly dead battery so that when the starter motor tries to turn it pulls the voltage so low the light looks like it goes out. You would get the same symptoms with a bad connection to the battery terminals.
Welcome from Pa
Battery / electrical systems are a pain to trace. Make sure the battery is sound than work forward.
I'm looking at buying a 2004 Honda VTX 1300. Is this the only problem you are having with it? Have you found the issue?
