1 - 10 of 10 Posts
Hey all, I am new to biking and working on bike. I am having a hard time finding out why my idle is so high on my 2007 Honda vtx 1300c. My bike was fine other than needing a carb rebuild. So I pulled the carb myself and cleaned it, reinstalled it and at first attempt, I blew out the oil deal at the transmission shaft because I accidentally hooked up the engine breather hose to a dead end, so it couldn't breathe. So I fixed those issues. Now, I start it up and it idles extremely high. I didn't have this issue before or even when I hooked the breather hose up wrong. Any suggestions??
Aging & Worn
This'll sound stupid at face value, but let's eliminate the obvious for starters............
Does this particular bike have a manual choke? Is it engaged?
Also, with regard to the Carb.......was it seated in a rubber boot with clamps? If so, are you sure the boot is fully seated?
Let's start there, and move forward.
-Soupy
-Soupy
Yes it has a choke. The choke is not engaged. When it is engaged, the idle gets much more higher.
The carb does attach to a boot. I tightened it up when initially installed, but I will double check the boot is still secure.
The bike does have an idle screw. I have the idle set to the lowest it can be adjusted.
Where is the air mixture screw set?
It's located on the Back end of the carb where it connects to the boot. It takes a special honda tool to adjust it. I don't have the tool. That's the only part I did not remove when I rebuilt the carb.
That could be clogged up.
Well I solved the biggest issue. I found that a vacuum hose came disconnected when I installed the gas tank. Now she runs around 1100-1200 rpms at idle, which is still a bit high, but a lot better than what it was. But now she's burning up fuel like a kid and candy. Would that be the A/F mixture? It spits a little when it's running. Does not back fire.
if it was fine before you worked on it the likelihood is theres a vac leak.
I use propane to find vac leaks on my car.
I use carb cleaner to find a vac leak.
The VTX 1300 is suppose to idle @ 900 +/- 100 according to the manual.
I got my A/F adjustment tool here:
http://www.glensvtxgarage.com/
These are good guys to talk too, there are a couple of sticky's that might help you out.
http://www.vtxcafe.com/forum.php
Basic trouble shooting 101. Go back to when the problem started. If you removed the carb to clean it, repeat your steps.
It takes these bike FOREVER to warm-up. Keep that in mind.
(Make sure your throttle cable is not binding)
1 - 10 of 10 Posts
