What are you saying 'whew'! for, he still has not fully traced out those passages yet and the answer still unknown.
Pic post #38, what is the passage ending around 7:00 in the pic? Where are the passages going to under the big rubber diaphragm? I don't see the twin idle air bleeds so the system has to add fuel rather than air and not clear at what point it does it with passages not fully traced.
Post #37......
'To test if Air cut of valve is sucking air from this passage i blocked it with finger and engine gradually died...'
The problem being if that is the idle air bleed you will kill it anyway and not tied to air cut at all. Did you ever put the spring back on top of that diaphragm if still using the whole rubber and steel center? If not a fuel leak there likely.
OP is getting lost in the details. If I had carb in hand it would be figured out in two minutes.
Post #37......
