hi everybody, i’m new to this forum, and also new to motorcycles. so please help me!
bought my first bike a few weeks ago, a 1971 cb350 with 722a carbs. it has aftermarket air pods + short mufflers. bike ran fine the first week i had it. then it started to have throttle issues. i would give it throttle, and the bike would struggle. the acceleration would go in and out, like a jerking feeling, and i couldn’t even get it to go 45 mph.
so i bought a carb rebuild kit from ‘4 into 1’ that also included new floats. bought a new petcock, clear fuel lines, and gas cap seal from ‘common motor collective’.
i cleaned out the rust in my gas tank, installed the new petcock and fuel lines, and cleaned the carbs and put in all the new parts (the parts were not of high quality as the emulsifier tubes wouldn’t seat and would slip right out, o-rings wouldn’t retain there shape, and the floats didn’t float as well as the ones previously in the carbs. i followed the youtube videos from ‘common motor collective’ and put the carbs back together.
all the prior carb parts i replaced were original keihin parts with the ‘k’ logo imprinted, besides the main jet. the main jet that was in the bike when i bought it was 115, secondary was 68. the kit i bought came with 100,105, and 110. i started out with 105 since i found online that 722a:
main primary jet: 105
main secondary jet: 68
slow jet: 35
pilot screw: 1 1/8 turn out
float: 26mm
so i installed all the parts to factory specs. fired her up, and noticed both float bowls were leaking out the sides. forgot to mention that before cleaning the carbs, the original floats were set to 23mm, but the floats had no spring action on the needles. but the original setup didn’t have fuel leaking out the sides of the float bowl.
rode around the neighborhood and still was struggling. same symptoms, but now the bike seamed to run lean. had a harder time setting the idle, and when i’d shut the bike off, i could hear pings inside the cylinders. engine was also noticeably hotter.
so i changed the main jet to 110. bike seemed to run better, not as much stuttering/cutting-in-and-out acceleration. the throttle ran smoother, but wasn’t getting enough speed, felt under powered.
so i thought maybe i should try the original 115s. so i replaced the old o-rings on the 115 with the 100s that came with the rebuild kit and reinstalled the 115s. back to stuttering/cutting-in-and-out acceleration.
so i checked the spark plugs, and both were black telling me the bike was running rich. so i bought new spark plugs and noticed the difference in power instantly. also,upon reinstalling the right side spark plug boot, the wire came off with ease. dunno if that had anything to do with it, but i cut the wire, and screwed it back on till it was tight.
rode around the neighborhood a bit, with the acceleration still stuttering, and checked the new plugs. the attached pic shows the spark plug on the left and the one one the right.
can someone tell me if these plugs are lean or rich?
can someone suggest how to fix this throttle stuttering problem?
i’ve been tinkering with this problem for almost 2 weeks now, and only have 2 hrs to work on it each day, since a neighbor complained and i have to be quiet in the neighborhood by 8. i’m so frustrated. i’ve probably taken off and put back on both carbs 20 times by now. i’d take it to a shop, but with the current problem, i’d struggle to make it there. towing will cost me an arm and a leg.
i just want to ride the damn thing!!! please help!
slow jet: 35
float: 26mm
