Hello, I just wanted to ask why my steering wobbles? The scoot is pretty much brand new, I just got it last Dec 2020. It starts to wobble around 25mph. any advice help would be appreciated.
Thanks!
Thanks!
I think for anyone to be able to answer this you'll need to give them much more detail. Exactly what is wobble? The obvious answer to wobble steering is something is not tightened down. Or is wobble really vibration and a wheel/tire isn't balanced. Although I'd expect a higher mph or mpk for that. But it could still be a tire that isn't mounted correctly. Do the handlebars literally almost jump out of your hands? Since it is new, can't you take it to the dealer you purchased it from to resolve the issue? You are still in a 30 window in worse case for repairs I would think. That's where I'd be headed.Hello, I just wanted to ask why my steering wobbles? The scoot is pretty much brand new, I just got it last Dec 2020. It starts to wobble around 25mph. any advice help would be appreciated.
Thanks!
Well there's your problem. That's much too slow to be trying tricks like that. Well, I'm thinking in relation to my bike, maybe it can be done on something smaller like what you have but I really doubt it. At least not for any length of time. That's not to say you don't have a tire problem or balance problem or something loose in the steering. But keep your hands on the bars until at least 40mph and preferably higher if you just have to show mom, "no hand".When I reached 20mph I let go of the handle bars. The it would shake violently but before it gets out of hand I immediately grab on to the bars before something gets bad.
It’s not that I’m doing tricks or anything. I mean, my other motorcycle does not wobble at all. It is just this particular motorcycle. I don’t know if it’s the tires or the balancing of the tires. I tried my other friends bike and it does not wobble like mine.Well there's your problem. That's much too slow to be trying tricks like that. Well, I'm thinking in relation to my bike, maybe it can be done on something smaller like what you have but I really doubt it. At least not for any length of time. That's not to say you don't have a tire problem or balance problem or something loose in the steering. But keep your hands on the bars until at least 40mph and preferably higher if you just have to show mom, "no hand".
It is a smaller displacement scooter called Honda ADV 150. Yes I have a windshield. The bike is only a month old so pretty much everything is brand new.Hi, there are not many reasons for this to happen. Low tire pressure is one of them. Bad (partly worn) tire also. What bike is it? Do you have wind shield? Normally, if there is a loose not on the axe, or damage frame, loose (damaged brake disc) the bike will wobble at higher speed, too.
Thanks Hog, a lot of fellow riders here said it’s one of the culprit since the bike is very lightweight.Believe it or not, what you are carrying on the tail could be the cause. A look on YouTube will show how wobble can be induced by weight placement on a bike. I was amazed when I saw it myself. I knew it might have some impact but never thought wobble would be one.
Probably is.what you are carrying on the tail could be the cause.
Probably is.
Any weight put on any bike that is farther to the rear (in back of, behind) the rear axle will upset handling big time.
This happens with full size bikes, no telling what it might do to a small machine. Also the higher the weight the worse the handling upset.
Pitch that big box and see what happens.
