I'm trying to put this one back in the dirt!
Bought it with the crank stuck. Got it free - but had to take off the head/cylinder to get it free. I did not have to split the case. I've put it back together and she spins good and generates what looks like good spark. But does not even try to start. I can spray "go juice" in the cylinder, put the plug in, and still not even a single hint of trying to start.
I put new rings (original size) when I had it apart. Using a low cost (HFreight) compression tester I get about 80 PSI which is probably low, but I would think it still try to run. I put new points and spark plug in as well. I have worked on the timing many times and I think it's right, but I have to wonder - I have the shop manuals and I think I'm following them but I can't help but think timing is my issue since I get nothing after spraying the go juice.
When setting the timing, at the instant the points open, both intake and exhaust valves are supposed to closed, right? I'm having real trouble getting the timing marks to even get close to lining up when setting the points. It seems to be far away (1/4 turn) from the mark with I reach the F mark on the flywheel?
Any suggestions to try appreciated! I have read most of the similar post's here that i can find but so far, no luck.
Thanks!
Thanks!
