I had idle issues a while back and found a vacuum leak that I fixed. I checked it again today and there seems to not be a leak. I went on a ride today and after a short time the bike would idle at close to 5k (even went up to 7k right before I was trying to check for the vacuum leak.
I have changed both the main and idle jets but I am guessing that is the problem since I have gone up many sizes (since I removed the factory air box).
Am I correct on assuming that my idle jets are too big?
Lastly, for the main jets - the throttle cuts out at around 9k (10k redline). Is that the opposite from the main jet, that it needs to be a bigger jet?
Thanks
Thanks
