1 - 11 of 11 Posts
· Registered
I've got a 1999 VZ800, it keeps over heating.
New battery, new switches, new ignition coils, carbs rebuilt, the bike has no thermostat.
Checked impeller etc. Any assistance will be appreciated thanks.
Tire Wheel Fuel tank Vehicle Automotive tire
Tire Wheel Vehicle Fuel tank Automotive tire
· SUPER MODERATOR
Welcome to a great forum! (y)
Thermostats are designed to keep coolant IN THE RADIATOR to maintain the correct temperature. I would drain all of the old coolant and put a new thermostat in and see if it helps.
Sam:cool:
Circle Symbol Emblem Crest Fashion accessory
· Registered
Discussion Starter · #5 ·
Sam:cool:
Thank you all for your guidance, however I've looked everywhere possible, but there isn't anywhere that a thermostat is missing, the bike didn't come with one.
Does anyone have a diagram of where it might be located?? Thanks in advance.
· SUPER MODERATOR
Everywhere possible??? A GOOGLE check found many topics about your thermostat:
Hand Car Hood Automotive tire Motor vehicle
https://duckduckgo.com/y.js?ad_domain=partzilla.com&ad_provider=bingv7aa&ad_type=txad&eddgt=Ay2ynD6ba6ecFtaN9EhR7Q%3D%3D&rut=49c83130b2aa12880564d90c82de2faf6fcb6da2862b8818740d09c4f2438222&u3=https%3A%2F%2Fwww.bing.com%2Faclick%3Fld%3De8oGeNNCVOJZ5aHYgy4MHzfzVUCUx8kaxY%2D0oKtyKF_FkHLadREoyjKk_bHu05vLkPOux_Qyijdw78ihO0IV%2DumKIDq9mJqdyAFfO_vHTe0qtEdreoCT6e0gl9ieNzLHVSVgT1uZLqjIMJy4Be%2DftSlmQPh0w25CzgONeOw4rSTLD6AeIKJkqbsrP3sJ2AVA52DPonjMSafmoemFra2E7XJYDqKg4Owq5eDdkvGFVtaECmBGL_HA9D%2DqeNcjoxyI7wqEdUgVfMehur3PZ_ddPmpOrzj3sGft%2D2lP5g6%2DgPUWi4p_3yWHIOavUBuBFiz4Ajp2QqHIu8rZmudsGxcRFH8E25nIu2JvGZ9PG9vtopTZllKRvcJh5uLjhbAp1U8Rp_oBqlOXNJVXaUoIaklJmdSrfS8tbGKOAzNBuzHfcUIJvIDBPS0J7993t9n0vGZQbrg47HabKmlcK0uYq3h8P4_NV2e%2D7428n9dkb1oY7OU6S3xqlLN4wpixDKKz5vFhWCfWdQPkOdoYvTmRFb0VNuTtuO_sKIcGPuta0TbUJQ1yhqHFzE0n_xiiL3p4NQHTNqTRagekMUApmc4D1M63VLk4Banm7Dy2mDFg1lbVYLGVUZTUZA3E1%2D%2DjCcwXlwYwCr2rRLqC_Mha0Vcu7c_1fJeU8lGYUCxirTGPvd0WJfXJ7HAAlntgzyhVe7p4Qlsi38oDhFDX3dm9xkdGp%2DOjG%2DTqGTxPShq8O_b42EVTAHBmJshWuoI7vFJVoNtTMqg01fmhzZ5g%26u%3DaHR0cHMlM2ElMmYlMmZ3d3cucGFydHppbGxhLmNvbSUyZmNhdGFsb2clMmZrYXdhc2FraSUzZm1zY2xraWQlM2RiNGI2MjBkMTM3NmIxOTZkMDI5YTQzMTdhMmViYzMxMCUyNnV0bV9zb3VyY2UlM2RiaW5nJTI2dXRtX21lZGl1bSUzZGNwYyUyNnV0bV9jYW1wYWlnbiUzZFROVF9UZXh0JTI1MjAtJTI1MjBPRU0lMjUyME9ubHklMjZ1dG1fdGVybSUzZGthd2FzYWtpJTI2dXRtX2NvbnRlbnQlM2RLYXdhc2FraQ%26rlid%3Db4b620d1376b196d029a4317a2ebc310&vqd=3-335767801595712138308512653986279609143-39501281590554844159392412597176649425&iurl=%7B1%7DIG%3D6E61F7E17B2B4D9C8FB05DDB7D2FB137%26CID%3D0E29E703890A621406C0F59F88EC63A5%26ID%3DDevEx%2C5045.1
· Registered
Discussion Starter · #10 ·
Removed every mechanism that is connected to the engine with regards to water passages, the only part l didn't remove is the connector hose between front and rear cylinders still no thermostat.
if the ignitor is malfunctioning will it cause the engine to advance and retard causing the engine to overheat to the point where you cannot sit on the bike.
· Registered
CB125T, EX250 commuter, Ninja 250 racebike, CBR250R(MC19), VF500F, CBR600RR, VFR750F
Did you back-flush radiator? Sludge in radiator will slow down flow and cause overheating.
Also did you answer question about fan? Does it turn ON when radiator gets too hot?
1 - 11 of 11 Posts
