My 1971 K1 SL350 is smoking from the left tailpipe. The conditions are:
With a hot engine, after I coast downhill with the throttle closed, when I twist the throttle a cloud of blue smoke comes out that pretty much covers the width of the traffic lane. These days, with the fires at all points of the compass, we do not need any more smoke in
The normal guess is a bad valve guide or oil-control ring that allows oil to be sucked into the combustion chamber under high vacuum. The left plug fouls with oil, so it is not leaking through the exhaust valve guide into the Xpipe.
By the way, the compression pressure is a healthy 180/170 pounds for the right/left side.
Engine history: About 2000 miles ago the left piston dome melted because of a lean mixture. I replaced the head with a used one, honed the cylinders with a hand drill, and installed 2 new pistons.
Am I correct that there is no valve stem oil seal on Honda 350 twins? Is this most likely a badly worn intake valve guide or a broken oil ring?
Thanks,
Larry in Pasadena
Thanks,
Larry in Pasadena
