1 - 8 of 8 Posts
I have a 2017 ruckus with about 16k on it. In the past 6 months, I have it worked on at the honda shop. I've had 4 valve adjustments. It's always exhaust tightening and he has already went down to the smallest shim and had me replace the valve. 2 adjustments ago. after less than 100 miles it won't start again. He advised me that the valve will need replacing as it already had the smallest shim in there. I asked if there was a way to fix the root cause as this clearly isn't normal valve wear. Maybe a camshaft? He said it has a lot of miles on it. It's probably just worn out. Is there an issue like the cam shaft I should be considering? Should I take to another shop? Thanks for your input guys.
The Ruckus is a pretty robust scoot. There are a number of them with even more miles than yours! That said, parts do wear out and smaller engines are somewhat more susceptible to wear. Something could be worn out. At minimum, I would recommend getting a second opinion. :)
Discussion Starter · #4 ·
That's a good suggestion. Actually checked the valve seats when we took the head off for the valve replacement. They are fine, the valve itself took the beating and looked like a flower (really thin towards the edges of the valve). Worth noting that was last time. We haven't taken the head off yet this go around but it's only been a few hundred miles.
Fuel mixture?
Discussion Starter · #6 ·
I carefully tuned the jets when I did intake and exhaust. The tech commented that the plug looked great, that I did a good tune.
Visionary
If a new valve didn't fix it then it's probably the seat as others said.
Did you take the head off yet and see what's going on yet?
1 - 8 of 8 Posts
