LA Sleeve. It's what they do.I opened the engine and transmission. Everything looks ok, I still have to take some measurement to check if everything is up to specs. Decided to clean the engine and polish the case. The only problem is that I cannot find a replacement for the broken cylinder sleeve. I’ve looked on ebay and other websites, is there somewhere else where I can find a replacement or is there another part that might be compatible?
Like Trials said... Something took out that rod. Maybe a hydraulic lock? Probable crankshaft rod journal damage there too.I opened the engine and transmission. Everything looks ok, I still have to take some measurement to check if everything is up to specs.
Here's the thing; the bottom end bearings on that engine are not roller bearings, they operate on oil pressure.Update.
I got most of the replacement parts. I haven’t checked the clearance on the rod bearings, but I replaced the bent rod. I bought a set of rods off ebay that claim to be from a same year model bike but have different part number. The ones off my motor have a 426 s21, the replacements have 426 s26. Either way I replaced the bent rod and the new one spins without any force but the other old rods spin much freely, without no resistance. Should I replace all rods? Are the replacemnt rods compatible? Are con rods suppose to spins so freely that I cant balance them standing?
You'll be able to visibly see the damage and wear on them.
The bearing "shells" (they are like a cylinder cut in half) are tolerance fitted to match each connecting rod and the crankshaft journal that it rides on.
You need to understand the technology being applied to even know what parts to order.
Do you have the entire engine apart and the bearing shells out that you can photograph? Don't mix them up they need to go back on the same place with the same rod or not at all. As for the con rod you are replacing, you will need to determine the correct bearing size and tolerance yourself for that one.
Really close there UK. It's Plastigauge. Green is about all most need to worry about.My memory tells me that the rod bearings need to be checked with plastergage.
From about 1974. Bruce our mechanic had a CB750 engine apart. I observed. Never did one myself. I would do the 2 stroke cranks. Bruce is also the guy who warned me off CB650 engines. Went on to work for Canadian Honda as their head tech guy. UKReally close there UK. It's Plastigauge. Green is about all most need to worry about.
Thank you for telling us that vacuum operated petcock was mean to save us from!! I will keep mine on vacuum as I was considering changing on my Virago 920.MAKE SURE you keep turning the gas off, that is likely what bent the other rod. It leaks into engine and hydraulically locks it to bend rod when you start it. What the vacuum fuel valve originally on bike was supposed to stop.
