Headlight, taillight and running lights all stopped working at the same time. Turn indicators still work; bulbs are good; fuses are good. I've replaced the ignition switch on the off-chance - still no luck! Anyone have any thoughts or suggestions? I'm at a loss, now.
I'd suspect the connection at the fuse box above anything else. That's the place that's common for all of those things. Either the fuse isn't getting contact or a wire could be loose. (Be sure to check the fuse with an ohmmeter or swap it out with a known working one, since sometimes they can look good visibly, but are bad)
Dodsfall - thanks for the info on the fuses. I had visibly checked them and all appeared OK. I'll go back and ck with an ohm meter to verify or switch out as you suggested.
