NordicMan, frankly, that new CVO series 110ci engine won't even compare at all to your Raider's engine. About the only thing in common is the V-twin and push-rods.
Dyno contests have proven that STOCK Harley's from EVO up, put out 40-45 rear wheel HP, from 1984 until 1999-2000 (?) when HD went to the Twin Cam. Still rear wheel HP was between 50-60. I don't believe that any of the big twins, even today aside from the CVO, 110ci engine bikes, put out more than 65 or so.
The 80 rear wheel HP is a step in the right direction but hardly laudable by todays standards. HD could add ported and polished 4 valve heads, dual injectors, as one for each cylinder, Light composite pistons and cylinders and an ECU that would allow more RPM's. Then of course a stronger clutch would be needed. I used Barnett Kevlar racing clutches on my builds.
Harley wants good torque and excellent fuel mileage and they have achieved that since Methuselah bought his first HD:biggrin:
Yamaha 1900 Raider:
"The 1,854 cc (113.1 cubic inches) four-stroke air-cooled V-twin engine was purpose-built to deliver maximum torque at 2,500 rpm in the 55 to 75 mph (90 to 120 km/h) range used for motorcycle cruising. Set at 48 degrees, the cylinders have a four pushrod valves, twin spark plug cylinder heads,[3] with forged pistons having an Alumite coating to reduce friction and ceramic-composite-coated cylinders.[2]
With an undersquare bore and stroke of 100mm (3.937 in) x 118mm (4.646 in), the engine has a compression ratio of 9.5:1 and is the first Yamaha cruiser motorcycle to be equipped with the compact Exhaust Ultimate Power Valve (EXUP) four-stroke power valve system previously only found on their line of high performance sports motorcycles.[2]
An unusual feature of the new engine is a special 'Pent-roof combustion chamber', designed to increase the efficiency of gas flow. The engine also has counter-rotating balancers on both ends of the crankshaft to reduce the vibration typical of large V-Twins.[4]
Horsepower is: 89.04 at 4,500 rpms (Stock)
Torque is: 114 lbs ft at 4,100 rpms (Stock)
PS: Ducati, even on their Supersport "streetbikes," with much smaller engines are within a few of 200 horsepower
Sam:biggrin:
