1 - 2 of 2 Posts
I am having some trouble with my 1984 Honda XL600r, Last week I was driving down a dirt road going 60 or so, when my bike suddenly turned shut off and my back tire locked. After slowing down a little bit, I managed to jump start it again and continue on with my trip. About 250-300 yards down the road it shuts off once again, but this time the tire didn't lock. After inspecting it a little big, I found that my compression in the engine was very low and I was able to push down the kick starter with my hand, with very little effort. However, when I do so the engine clicks a whole bunch. I had a friend say he had the same thing happen to him, and that it was a spark plug problem, after taking it out and putting a new spark plug in, I found that was not the solution to my problem. While the spark plug was out, I tried pushing down the kick starter and it blew air out of the whole where the spark plug goes, I believe meaning it still has compression. If this same problem has happened to you, and you were able to fix it or you know how, I would be thrilled if you would tell me. Thanks for your time.
Ghost in the machine
Air coming from thr spark plug hole does mean you have compression. The question is how much, 1psi or 120psi ?
You need to perform a compression test with a gauge. Then let us know the results and someone here can probably help.
Also I believe that bike has a compression release valve to aid in starting. Make sure it is working properly before doing the test.
1 - 2 of 2 Posts
