Hi all,
I recently bought a Suzuki GS500 (02 reg) and I've been having problems with the battery. Initially I thought the battery was at fault however I've replaced this and still have issues.
If the bike is not used for a few days the battery has little charge left and when i go out for 20 miles rides it doesn't appear to be charging at all. Actually, the bike frequently cuts out towards the end of these rdies and then I can't get it started again due to dead battery.
I've followed the steps to check the R/R from the John Bates charging circuit test (and a bunch of other guides). Measurements are:
1. (battery) All off = 12.88 / 13.12. Idle (1200RPM) = 13.9. 2500 rev = 14.2. 5000 rev = 14.15 (However, this doesn't always happen, sometimes there is no increase)
2. 14.2
4. 60mv
6. 48mv
8. y1-y2 = 1.5 ohms. Y1-y3 = 1.5 ohms. Y2-y3 = 1.4 ohms
10. OL for all
12. y1-y2 = 65v. y1-y3=66v. y2-y3 = 65V
14. Red – y1 = 498mv. Red-y2 = 510mv. Red-y3 = 513mv
16. OL for all
18. y1 =514mv. Y2 = 512mv. Y3 = 510mv
Stator current (AC) at 5000 RPM between leads:
65v, 66v and 65v
These readings suggest that the stator is OK. According to the guides I'm using the readings for the R/R (14-18) are too low but they are all consistent.
The connection with the Red and b/w connects to the cable coming from the R/R and looks damaged/corroded. The yellow wires that also connect up to those coming from the R/R get fairly hot to the touch.
I'm not too sure what is going on here.
2. 14.2
4. 60mv
6. 48mv
10. OL for all
16. OL for all
65v, 66v and 65v
